fuel screw question
Old Nov 21, 2011 | 07:10 AM
93-12Smoke's Avatar
fuel screw question
Ok, so I'm almost done rebuilding my injector pump and I have a question about my fuel screw . Prior to removing it I measured it using vernier calipers. Verified the measurement three times. When reinstalling it it feels like it's almost bottomed out to get the same measurement as o got before removal. could something be out of whack in the pump? I know my measurement is accurate and by far better than just marking the screw. Any idea? Thinking about backing it out a ways and then readjusting after I get it cranked. Wanted to keep my previous settings as I am fixing to make some other upgrades and dyno again to see my gains.
Old Nov 21, 2011 | 07:25 AM
BC847's Avatar
1st Generation Admin
I vote for this.
Old Nov 21, 2011 | 08:20 AM
dzl_damon's Avatar
You may have inadvertently already been about bottomed out. I had to add about 1/4" to the end of my fuel screw before it would hang up in my 93.
I would do as David already agreed with, and go from there.
Old Nov 21, 2011 | 11:20 AM
93-12Smoke's Avatar
Well I had to remove the cover again anyway so I ran the screw back in. Still gets tight at the same point but I went ahead and left it 2 turns out. Will fine tune it on the truck.
Old Nov 22, 2011 | 12:22 AM
Jim Lane's Avatar
Make sure you have a block of wood or aluminun to block off the air supply in the event of a runaway.
It is kind of scary when you are leaning in the engine when it happens.
Old Nov 22, 2011 | 12:43 AM
93-12Smoke's Avatar
Been there done that
jmd4993
Jun 22, 2013 07:36 AM
Boatnik
Sep 19, 2006 08:00 AM
440forPOWER
Jul 13, 2006 06:33 PM
loudcummmin
Oct 3, 2005 02:44 PM
