Fuel Pump Replacement: Just watched the videos...have a q or two
Old Dec 8, 2010 | 09:11 AM
Subliminal's Avatar
Hey guys,
I just watched the Master Tech 91-93 fuel pump replacement videos, but I have a few clarifying questions:
1. I don't think I need the barring tool, as I can simply rotate the engine by the alternator pulley, correct?
2. The t bar gear puller. Can anyone go into detail on a way to do this without purchasing a high-priced tool that I won't use more than once or twice?
3. That's actually all I can think of. Anyone who has done this have any pointers for the kid?
Old Dec 8, 2010 | 09:15 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
i use a 15mm socket on the harmonic balancer bolts and rotate it clockwise so you know youre not loosening them up. seems to work great. i cant get mine to turn on the alternator without the belt slipping.
any tool i need but cant afford i usually borrow. when i skipped my pump gear i just borrowed the local shops gear puller and brought it right back.
Old Dec 8, 2010 | 09:18 AM
Subliminal's Avatar
Think this would work?
http://www.autozone.com/autozone/acc...mString=search
Old Dec 8, 2010 | 09:20 AM
i think the gear threads are m8 1.25. if youre removing the pump gear then youll need that size.
Old Dec 8, 2010 | 09:27 AM
Subliminal's Avatar
Ha...found this thread:
http://www.cumminsforum.com/forum/98...ternative.html
Seems like it'll do the trick.
Anything else that might not be straightforward?
I'm gunna kill my engine vibration if it kills me! It's gotta either be the pump or the clutch assembly...and I don't really want to pull the tranny a third time yet...
Old Dec 8, 2010 | 09:29 AM
dont lost the key out of the keyway when you pop it off. that will tick ya off.
Old Dec 8, 2010 | 09:31 AM
Subliminal's Avatar
Yeah, i'll bet...but I guess if I did lose it, that'd be a good reason to finally kill the dowel.
Old Dec 8, 2010 | 01:45 PM
d22019's Avatar
I did mine not too long ago and its super easy. Be sure to check the timing pin to make sure the little tip is still on it.
Old Dec 8, 2010 | 06:44 PM
Subliminal's Avatar
Nice. Yeah the videos made it look pretty easy, honestly. Kind of surprised the guy didn't wear gloves, though.
Old Dec 9, 2010 | 10:43 AM
dodgenstein's Avatar
I use a steering wheel puller and 2 bolts form the airhorn. (These are the ones that bolt the airhorn and grid heaters to the intake).
stinkindiesel
Sep 12, 2008 11:26 PM
t-15 firefighter
Jun 1, 2007 09:02 AM
Badd Dogg Guy19
23
May 11, 2006 07:16 PM
y-knot
Feb 2, 2004 01:43 AM
