Fuel pressure gauge
Old Sep 7, 2012 | 06:01 AM
j_martin's Avatar
Fuel pressure gauge
Want to put a fuel supply pressure gauge on the first gen. Looks like the best place to put the sending unit would be to replace the bleed banjo bolt on the fuel filter with one that has a 1/8" pipe thread hole instead.
Do I hack the one I have, or is there one available?
I could pull it and measure it if I weren't so lazy.
Old Sep 7, 2012 | 08:58 AM
thrub's Avatar
Pretty sure Geno's Garage has them.
Old Sep 7, 2012 | 09:19 AM
BILTIT's Avatar
Buy a snubber, i think this is the one you want.
http://www.genosgarage.com/RLT-SNUBB...o/RLT-SNUBBER/
http://www.genosgarage.com/AUTO-METE...tinfo/AM-3279/
http://www.genosgarage.com/BANJO-BOL...F-LONG-TAPPED/
Old Sep 7, 2012 | 10:53 AM
j_martin's Avatar
Thanks all,
Ordered the bolt and a coupla gaskets from Geno's.
Don't think I'll need the snubber with the stock lift pump.
Old Sep 7, 2012 | 12:49 PM
thechoochlyman's Avatar
I didn't use a snubber, but I did put a needle valve in the line about 1/2 turn open.
Old Sep 7, 2012 | 02:21 PM
j_martin's Avatar
This one's electric. I probably has snubbing built into the sending unit.
Old Sep 7, 2012 | 02:27 PM
BILTIT's Avatar
You will want a snubber with the stock lift pump and electric pressure sensor. You can put a needle valve in as mentioned above.
Old Sep 7, 2012 | 02:29 PM
Exekiel69's Avatar
I have a piston lift pump on mine and already burned one gauge for not using a snubber. Do what You think is best with Yours but good gauges are not cheap and the pulsations from a lift pump will eventually get the needle bouncing and kill the gauge.
Old Sep 7, 2012 | 03:29 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
put a needle valve in... DAP has them for like 11 bucks shipped. i have a snubber and it didnt help at all. the needle valve took all the pulsing out of the gauge, plus if i get a leak (mechanical gauge) i can shut off fuel right at the banjo bolt.
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
