Fuel pressure fluctuation
Old Mar 11, 2015 | 12:39 PM
BCRick's Avatar
My truck has been running great but yesterday I noticed my fuel pressure gauge, which has always run at 3 to 5 pounds of pressure was running steady at 7 pounds and going up to 10 pounds. It has not done this before and I would like to know what would cause this and is it a sign of something to check. I have the stock diaphragm lift pump. no leaks or other visible problems.
Old Mar 11, 2015 | 02:34 PM
cougar's Avatar
7PSI at idle is typical for the diaphragm in good condition. Sounds like it is starting to fail. Time to replace it with a piston lift pump. Look for the FAQ in the "Sticky" section for instructions.
Old Mar 12, 2015 | 10:41 PM
MrFusion's Avatar
I have a diaphragm pump on mine with a fuel pressure gauge and snubber run off of the bleeder fitting (replaces banjo bolt and bleeder). The gauge bounces between 4 and 5 psi at idle. No idea what it does past idle.
Maybe you have a gauge or sender problem. I wouldn't think a failing diaphragm pump would increase in pressure.
Old Mar 13, 2015 | 02:58 PM
BCRick's Avatar
That's what I don't understand. A failing pump I would think would lose pressure. The gauge is post filter with a needle valve to control pulsing.
guily
21
Feb 12, 2008 12:06 PM
MARKY MARK
Jan 16, 2008 07:12 PM
MARKY MARK
Feb 26, 2007 07:39 PM
Awall
Oct 28, 2006 12:15 PM
Haulin_in_Dixie
Jan 7, 2005 04:28 PM
