fuel pins
Old Feb 16, 2010 | 08:52 PM
Roll'n Coal2010's Avatar
fuel pins
which is the best fuel pin dennyt,bully dog...etc?
Old Feb 16, 2010 | 08:57 PM
Firstgenfanatic's Avatar
I am personally running an M&H "M5" fuel pin. This is a locally brewed pin
The Denny T is an excellent pin from what I have seen and heard. The Bully-Dog is supposedly made of poor material and grooves easily. I think there is an "Old Smokey" pin out there too! Good stuff.
I guess whatever your personal preferance is............
Old Feb 16, 2010 | 08:58 PM
M&H or DennyT
Stay away from Bullydog, BD, old smokey. they groove real bad and don't give you as much power as a dennyt
Old Feb 16, 2010 | 09:29 PM
westco's Avatar
I saw a vid on youtube....I think it's yours Crossy's, where you turn the pin. So is it not necessary to replace it to gain performance?
Old Feb 16, 2010 | 10:22 PM
93Fury's Avatar
Turning the pin will get you a little bit, but my god put an aftermarket (M&H or DennyT) and you'll be amazed.
Old Feb 16, 2010 | 10:44 PM
JustRamIt91's Avatar
just hope your converter or clutch will be able to hold on.
Old Feb 16, 2010 | 11:43 PM
whereswaldo250's Avatar
I have a borrowed denny stage II (early one), and with the pin it made a huge difference. It all depends on what you do with your truck, play or tow. You can't go wrong with your decision.
Old Feb 17, 2010 | 06:42 AM
Bob Beauchaine's Avatar
I would second DennyTs Stage II. I've been running one for quite a while. It gives excellant performance when needed and my last fill showed 19.91 in mixed city/highway driving.
Bob
Old Feb 17, 2010 | 07:50 AM
sdseva's Avatar
where can you order the M&H pin from? good things have been said about the stage 3 for drivability and fun
Old Feb 17, 2010 | 10:27 AM
westco's Avatar
I saw the M&H on ebay....how's it compare to Denny T?
Old Feb 17, 2010 | 12:55 PM
92smokin blacky's Avatar
get a Denny T pin and run no washer and thats probably the most power you can get out of a fuel pin. Just don't get a bully dog pin, they groove, don't ask me how i know
Old Feb 17, 2010 | 01:55 PM
DennyT is more of a strictly performance pin due to the fact it had a deep cut.
the M&H is made by a member on here and he offeres 5 profiles, they all give max power when your foots to the floor but its at low boost conditions where the different profiles come into play.
They're both good fuel pins, it just comes down to what you're doing with your truck.
Old Feb 17, 2010 | 06:15 PM
1985cucv's Avatar
denny t stage 2 all the way good piece and worth the money! contact him on here his name is dennyt!
Old Feb 17, 2010 | 08:19 PM
93John's Avatar
The dennyt works good all around. You can always tweak the aneroid a little to compensate the steep ramp.
Old Feb 17, 2010 | 08:36 PM
i think im going with the denny t. any good websites that sell 1st gen stuff?
