fuel injector pump leak
Old Jan 13, 2007 | 09:23 PM
OLDDDOGS's Avatar
I have a small fuel leak coming from a small line ( looks like it could be a breather of some sort) on the injector pump. It is a 1990 with 195000 miles. the line is right below the diaphram on the injector pump. Any Ideas? Thanks
Old Jan 13, 2007 | 09:48 PM
DieselSmith's Avatar
have you used any ULSD yet?
Old Jan 13, 2007 | 10:10 PM
Boatnik's Avatar
If it is the vent to area under the AFC diaphram it may be the "o"ring seal to the small pin that rides on the Fuel pin. I replaced mine a few months ago. It is not too bad a job but it involves removing the top of the IP and driving out a fulcrum pin that is held in and sealed by a couple of hardened steel *****. Since you may already may need to go in there, it would be a good opportuniy to replace the stock governor spring with a 3200 rpm spring. Bosch sells overhaul kits for the VE for about 25 bucks that has the seal and a whole lot more. The 366 spring can be had for about 13 bucks from the same source. The best place to try to get these parts my be from a fuel injection repair shop.
Old Jan 13, 2007 | 10:13 PM
Boatnik's Avatar
I've been forced to run ULSD since October and I have yet to have a problem that I could attribute to the new fuel except the less power, lower EGT's and less miles per gallon. And of course, NO PRICE BREAK!
Old Jan 14, 2007 | 08:09 AM
Ace's Avatar
Ace
If anyone has NOT been using ULSD, the Federal Highway Administration and EPA would like to hear from you.
Old Jan 14, 2007 | 10:42 AM
thats absolutely true lol. but I'm sure laws about not using it aren't valid yet; from what I've heard they are still in the process of getting the fuel to 15 ppm at the stations, as the 500 ppm is still mixed in.
All I know is that the ULSD sure tore my pump up, with leaks from several locations. Got it rebuilt, and no more leaks, but I run a stanadyne additive just to be safe.
Old Jan 15, 2007 | 10:38 AM
dpuckett's Avatar
I had the same leakage with my pump with the ULSD. Mom's as well, now. I had mine redone by Bryan Banghart, and he seems to have done well. I resealed one on my own last OCtober, right as the new fuel came out, so I should be ok on that one.
OLDDOGS- That leak is likely the AFC guide pin o-ring. Once you get into the housing, the lever off and out of the way, there is an allen wrnech set screw that keeps the o-ring in place. Just wanted to let you know. I spent an hour trying to figure out how to get that little retainer out. Had the old o-ring out with a pick in no time, but couldnt get the new one back in.
Daniel
DAFF
Dec 23, 2008 01:17 AM
Bob Hawthorne
Mar 15, 2008 08:22 PM
ramlovingvet
Jun 24, 2004 09:26 AM
