Fuel dilution
Old Mar 19, 2022 | 01:06 PM
nothingbutdarts's Avatar
Fuel dilution
I am not sure if I am getting fuel dilution since I don't drive the 89 very often. I do know here recently that the VE pump is leaking externally when running. I have not started the truck in months, if by chance fuel was getting in the oil, would it separate out after sitting so long like water will do in oil? I was thinking of draining the oil into a clean pan and watch to see if it is actually getting diluted or I over filled it at some point.
Thank You!
Old Mar 19, 2022 | 04:01 PM
u2slow's Avatar
Fuel would usually leak into the crankcase most when running, so it gets blended-in promptly.
Key entry points would be the front VE pump seal, and diaphragm lift pump.
Old Mar 20, 2022 | 06:57 AM
You might be able to tell by the smell of the oil.
Otherwise "making" oil when it is running is the usual first sign of one of the pumps u2slow listed.
Old Mar 20, 2022 | 12:44 PM
edwinsmith's Avatar
Having a lift pump that puts out to much pressure will force the front seal out of the VE and put about 7 gallons of fuel in your crankcase. Ask me how I know.
Old Apr 1, 2022 | 12:57 PM
ScubaSteveCA's Avatar
5 Year Member
Send a sample of your oil off to Blackstone, they will check for diesel in the oil. I did it not too long ago and it was 35 bucks. Turns out I had just overfilled it by a little.
Federic
Sep 13, 2020 09:31 PM
90 power ram
Mar 12, 2011 02:15 AM
SILVER GUS
Nov 15, 2008 05:34 PM
Redliner
Apr 2, 2008 09:11 PM
genros
May 30, 2005 05:37 PM
