Fss?
Old May 20, 2018 | 01:26 PM
nonrev's Avatar
Super Moderator
10 Year Member
Fss?
Ok so I got fuel yesterday went to start the truck, it would spin over as normal but no start, so checked the wires on the fss, both on and hooked tight so pumped the primer a few times it was on the lobe so I had the wife bump the key and presto it fired right up.
Now this morning I change the oil and when I went to start it and again no go so I primed it about 20 pumps still no go, banged on the fss it fired right up. I guess my question is has anyone had the fss stick in the closed position?
Old May 20, 2018 | 02:25 PM
nonrev's Avatar
Super Moderator
10 Year Member
Well I removed the fss it appears normal seems to work like it should, is there something in IP that could be going bad?
Old May 20, 2018 | 03:11 PM
mknittle's Avatar
Mine did that when the fuel heater O-ring went bad.
Old May 21, 2018 | 11:02 AM
maybe368's Avatar
Yup, I was going to say suction side air leak...Mark
Old May 21, 2018 | 05:47 PM
nonrev's Avatar
Super Moderator
10 Year Member
Well it has been starting every day so far, one thing I did check was for leaks in the system by putting 8 lbs of air in the tank, would that make the fuel heater leak if the oring was bad
Old May 22, 2018 | 10:16 AM
maybe368's Avatar
It should, but it seems that you have a very small leak. See what happens when it sits a day or 2. Maybe it has fixed itself, Ya' gotta' love it...Mark
Old May 22, 2018 | 03:11 PM
nonrev's Avatar
Super Moderator
10 Year Member
Ha Ha this poor old girl never gets to rest for more than about 12 hours 👀
Onemoparnut
Jan 3, 2021 11:51 AM
The_Head
Nov 16, 2010 03:00 PM
NE frmhnd
Aug 9, 2010 06:44 AM
schamran
Feb 1, 2010 09:36 PM
