front spring help
front spring help
Im looking to do new front springs on my d350. Which ones would yall suggest? Im looking to bring the front up some as well. Also im just curious what all would I have to do to put a small body lift on it? Or is it even worth it
Check the sticky. It's all been done there.
https://www.dieseltruckresource.com/...d.php?t=217632
https://www.dieseltruckresource.com/...ad.php?t=93841
I put a 1 inch body lift it my 90. Only the rad shroud needed minor relocating. The front bumper looks alright in the stock position, any more lift though would require the bumper to be raised. I put the small body lift in to give more clearance between the cab and trans tunnel. When I changed the clutch on my 93 the getrag was catching on a body seam in the tunnel. We'll see if it helps when the clutch needs to be done in my 90.
DNRCustoms
Nov 24, 2008 09:30 PM
WhoCares79
Jun 3, 2008 11:45 AM
flynhigh205
Feb 26, 2008 10:33 AM
fishin fever
Mar 13, 2006 06:46 PM
