front & Rear diff fluid maintainence
Old Apr 11, 2008 | 05:22 PM
jj3500's Avatar
servicing my diffs in my 89. What is the desired fluid for this rear? brands....and also, synthetic or regular. While I'm at it, transfer.
Thanks!
Old Apr 11, 2008 | 06:03 PM
Depends on the use. If it's just puttering around town and hauling an occasional bed full of dirt, standard 80W-90 is fine. For heavy towing, I'd put an 85W-140 synthetic out back. Dino 80W-90 is fine up front no matter what the application.
Transfer case gets 80W-90 as well, no need for synthetic there either.
Old Apr 11, 2008 | 07:38 PM
93beater's Avatar
80/90 in front and rear with a limited slip additive, i run 80/90 penz gear oil with the 1/2 quart of lucas motor oil additive in front rear and t case, helps the clatter, thickens the oil for less breakdown, imo its better than any limited slip additive, and i work @ a lube/mechanic place so i see this a lot! good luck for lots of pulling and heavy haulin 75/140 should do the trick but dont forget the lucas, or some additive its a must!
Old Apr 12, 2008 | 01:10 AM
bigredbrick's Avatar
I'm running Royal Purple in both diffs, 80w-90 in front and 85w-140 in the rear. Straight 50 motor oil in the t-case.
Old Apr 12, 2008 | 03:19 PM
dpuckett's Avatar
I run a synthetic 75-140 in the rear, with 2 bottles of friction modifier just to make SURE it doesnt grab around corners in town.
T-case will get the same oil, and the front probably will, too.
I think anywhere you can run a synthetic and cut down on frictional losses is good, esp with $4+ diesel.
Daniel
banana
Dec 1, 2009 11:44 PM
rich in co
17
Oct 18, 2007 08:33 AM
jwhip
May 22, 2006 12:21 AM
lucey
Jun 20, 2005 09:02 AM
JImbo1
Apr 12, 2003 10:46 PM
