Tranny Fluid & Rear/Front Diff ?
Old Jun 19, 2005 | 08:27 PM
lucey's Avatar
How much of each will i need for my 48,000km service. I think the ATF+4 is 4 litres and the fr/rr diff fluid is approx 3.5 litres each. Is this correct ? Also is it worth spending the money on the Redline for the diffs or would Valvoline diff fluid be enough ? I currently run the Valvoline Premium blue in the engine.
Old Jun 19, 2005 | 08:56 PM
TonyB's Avatar
If your a maintenance nut like me, buy a mag-hytec cover for the diff. No, I'm not associated with mag-hytec, just a satisfied customer.
Check them out: www.mag-hytec.com
HTH
Tony
Old Jun 19, 2005 | 09:07 PM
lucey's Avatar
I plan on buying all the pans tranny and diff covers
Old Jun 20, 2005 | 08:48 AM
Lightman's Avatar
Lucey - check out the pml covers, they are just as good as the mag hytecs but are much less expensive.
Most people seem to use mobil 1 75w90 diff fluid, and some that tow really heavy use 75-140. I'm not familiar with the valvoline diff fluid, but if it's fully synthetic I'm sure it would work fine. If I recall correctly, the front takes about 2.5-3 quarts and the rear takes 3.5 quarts. This last time I replaced my rear diff cover with a PML. It now takes 5 quarts. The trans if you just drain the fluid and filter should be about 6.5 quarts to refill.
Old Jun 20, 2005 | 09:02 AM
rossn2's Avatar
Transfer Case (up to 5pts/3qts)
Man. Trans. NV 5600 ( 6 Spd 9.5 pts/6 qts)
Frt & Rear Axle (up to 5 pts frt & 8pts rear/8 qts)
banana
Dec 1, 2009 11:44 PM
jj3500
Apr 12, 2008 03:19 PM
rich in co
17
Oct 18, 2007 08:33 AM
jwhip
May 22, 2006 12:21 AM
Relentless
Oct 6, 2003 06:46 AM
