Front Hub
Front Hub
The bearings went out on the front end of my Grandfathers truck and goobered up the the wheel hub. We cant find one anywhere. Were can I find one? The truck is a 1993 3/4 ton, 4x4 ext cab with the 4500# front axle.
-Kyle
-Kyle
It shouldent be that hard to find one. try a good 4x4 hard parts shop. Ive even gone so far as to call the Dana co. direct. In a earlier post in the first gen section someone mentioned a Dodge only wreckin yard in Sacramento ca. Ill try to find the name and number for you. Also im not sure on interchangeability, but the 75 ford F250 I had also used the Dana 60 HD frontend. If I remember right the hubs were much bigger lookin than the ones on the 93 350 I sold a while back. Also it wasent a dually as Im assuming yours is?
'93 hubs are the same as the Chevy dana 60 hubs. They seem to be a little hard to find, but are popular with the rock-crawler crowd. There used to be new ones listed on e-bay pretty regularly. If you can find a Dana dealer, you should be able to do okay as well. I think the hubs are out of production, but they were common enough that you should be able to find one for a reasonable price.
You could try Mikes parts Mike on the internet he carries lots of parts for dana diffs www.partsmikeparts.com
DiEseLjunKy
32
Dec 27, 2007 07:37 AM
Crimedog
Feb 27, 2007 10:39 PM
