Front Control Arms pop
Ever since I've own my 90 D-250, it has made a popping noise in the front when I hit a bump while the wheels are turned. Thinking since the truck is almost 20 years old & holding the weight of the Cummins engine, it may be time to put some new bushings in. May as well do upper & lower "A" arm bushing while I'm at it. Any pointers or what brand u all have worked well. Looking for alittle input on the project.
Look through the threads, there was a poor soul who had the same symptoms as you and his lower control arm mount broke off. It was scary looking! I know I went out and checked mine that day! Find out what is wrong. Ball joint failures are not uncommon, nor are they pretty.
Yeah mine does that same thing. Like wanna said its probably just hitting the stops. I have greased mine before and the sound goes away for awhile. Just not the best design for a stop in my opinion.
I see. It only does it on the right side, no matter what direction u turn. I have done ball joints on the left side, but not the right yet. There aren't any grease fittings around the wheel stops, are there? First time I've ever heard of this.
the496rocket
Apr 13, 2009 08:22 AM
hellotbone
Nov 21, 2003 07:44 AM
