Front Coils
Old Jul 4, 2005 | 01:31 AM
rockjeep73's Avatar
Front Coils
Where can I get front replacement coils for my 1st Gen?
Old Jul 4, 2005 | 11:03 PM
Micaiahfied's Avatar
i believe the most popular part number is 7226S (by MOOG i think) these springs are supposed to level the truck out and keep it from sagging. i've been told you can pick them up at NAPA. i'm sure others that have used the springs will chime in.
Old Jul 5, 2005 | 12:15 AM
runamuk's Avatar
I have an in at 4wheelparts wholesalers here in Sacramento.
Do you have all the necessary equipment to change them?(I've got that too).
Rick
Old Jul 5, 2005 | 01:26 AM
loch's Avatar
if you want a bit more stiff use ones out of a 1 ton, and just to enlighten you they are a breeze to change. if you can get ball joint off and support the truck the a frame comes low enough to slip them in and out by hand, also dont be suprised if they are broke, both of mine were,,,they were gasser springs, the heave ones came out later. just make sure the spring end is in its little slot wont hurt if its not but it will slip in on its own and scare the bejeevies out of you.
Old Jul 5, 2005 | 03:32 AM
Jim Lane's Avatar
Springs
I got my front springs from local Dodge dealer, They only listed the 4000# ones still available. I also replaced the rubber isolator bushing that sits on the top.
Be careful when you release the lower control arm and keep all body parts out of the way.
The job was pretty simple.
Jim
Old Jul 5, 2005 | 05:58 PM
Den's Avatar
Den
Do a search on here. There are 2 different springs that are numbered very closely. One has a full coil on the top and the other is ground down flat. The full will give you a little more height.
check this thread out
Den
mstep3
44
Jan 18, 2010 09:01 AM
B.A.Ram
Oct 8, 2005 02:00 PM
Micaiahfied
Jul 2, 2005 03:04 PM
Kevins
19
Mar 14, 2005 08:14 PM
1ST CUMNZ
Feb 14, 2003 10:37 AM
