free hy turbo question
Old Feb 12, 2012 | 09:17 PM
DEFlush's Avatar
I got a free hy35? with the 9cm wastegated housing but i dont have the elbow for the back of it. i know the elbow woldnt work on my stock exaust anyway. I was reading some posts about people doing this swap to stock trucks but i have no idea what piece they are using for the flange. does anybody have any info on a part # or somthing i can mod in there without hackin up my stock tubing?
Old Feb 12, 2012 | 11:11 PM
Mark Nixon's Avatar
IF it is truly an HY35, the back cover on the turbine housing unbolts with 5 (?) bolts.
If it's truly an HY35, the back cover off an HX35 bolts on.
The earlier HX35 one is the band-clamped on style, whereas the later HX35 and the HY35 have the elbow cast into the cover.
Some places actually offer the covers in steel, POSSIBLY with a larger outlet.
Mark.
Old Feb 12, 2012 | 11:16 PM
jimbo486's Avatar
If you can only find or consider a later HX-35 or HY-35 rear cover with the integrated cast elbow, you can run a 2nd gen 4" downpipe as a few guys here have done. I'm considering it one day to eliminate the "S" turn of the factory 3" and aftermarket 4" downpipes and just have more of a sweeping elbow. Seems like it would be easier flowing but that's just my thinking.
Here's a link to a recent thread regarding the HX/Y-35 outlet. The guy who started the thread made his own outlet flange. One picture is of the integrated cast elbow that Mark mentioned. I don't see why a 4" flange couldn't be used instead of a 3".
https://www.dieseltruckresource.com/...e-t299516.html
Old Feb 12, 2012 | 11:22 PM
u2slow's Avatar
If you can't find one, BD Power makes a copy of the stock flange/adapter. Its $63. I made my own from some plate and the flange off an old downpipe.
Old Feb 12, 2012 | 11:23 PM
u2slow's Avatar
Originally Posted by jimbo486
If you can only find or consider a later HX-35 or HY-35 rear cover with the integrated cast elbow, you can run a 2nd gen 4" downpipe.
You have a pic of that? I might want to try it out on my D250.
Old Feb 12, 2012 | 11:31 PM
jimbo486's Avatar
I just edited my original post and linked to your thread .
Here's a link to and a picture from a thread I found after searching. The cast elbow used is slightly different having a v-band flange on it but the 2nd gen 4" downpipe would bolt to either the integrated elbow or the v-banded elbow. Obviously, it's an h1c turbo.
https://www.dieseltruckresource.com/...e-t190505.html
Old Feb 13, 2012 | 01:28 AM
DEFlush's Avatar
Mark.
yes mine is the 5 bolt version. is there a specific one i need for my stock exaust or are they all the same. ie flange size or shape?
Old Feb 13, 2012 | 03:23 PM
92smokin blacky's Avatar
I ran an Hy35 a few years back and it was a nice upgrade, especially for free. It will spool instantly. Mine had the 45* cast elbow like in the above pic. I did get a 2nd gen 4" downpipe to fit in my truck with this turbo/elbow setup.
We swapped an hy35 onto my buddys 92 and used the v-band clamp style flange off an hx35. We took his elbow off and put the hx35 v-band flange on, then he could clamp it right up to his stock exhaust.
Old Feb 14, 2012 | 01:47 AM
DEFlush's Avatar
I know its a little unrelated to this thread but what is the best way to remove the greasy resdue from the compressor housing. i see that there is a large snap ring but i would like to leave it assembled if possible. maybe mild degreaser or carb cleaner?
Old Feb 14, 2012 | 12:57 PM
Yes that would work. Last two housing's I cleaned with aluminum acid cleaner then wire wheeled them to a shine. I sandblasted the exhaust housings. Of course this was with the housings off.
Old Feb 15, 2012 | 12:23 AM
u2slow's Avatar
I've never taken a turbo apart until recently, the snap ring came out easy with some channel-lock pliers. The housing comes right off. No big deal at all. My HX35 was keyed with a tiny roll pin and a notch - easy to put it back with the same clocking again.
I washed the housing in the solvent tank at work, and blew it off with compressed air. Done.
w250_93
Jan 11, 2009 10:06 PM
Country23047
20
Apr 23, 2008 09:59 PM
Mark Craig
Aug 26, 2005 07:57 AM
Mark Craig
Aug 25, 2005 04:22 PM
