Frame question
Old Jan 21, 2010 | 02:00 PM
ups132's Avatar
Frame question
Whats the difference between a regular cab 4x4 91.5 ton dually frame and an extended cab 4x4 92 3/4 frame. both are five speeds if that helps. which one is heavier built i guess is my question.
Old Jan 21, 2010 | 04:46 PM
They should be the same cross-section, just different lengths.
Old Jan 22, 2010 | 12:12 AM
440trk's Avatar
The frame area under the cab is different between a Club Cab and a Reg. cab. The Club cab has a longer drop to compensate for the longer cab. Also the Cab mounts and such will be in the wrong location.
Old Jan 22, 2010 | 09:43 AM
deking1970's Avatar
Actually the drop area under the cab is the same on a club cab and a reg cab. The difference is the length behind the drop. The rear floor of a club cab is higher. So you could put a club cab on a reg cab frame. Cut 4 inches off of the back of the frame and make a club cab short bed. You would have to move the rear cab mounts back also.
roxxx
Nov 19, 2021 03:07 PM
Tyheethan
Feb 25, 2009 12:12 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
