found the carnage
Old Oct 13, 2008 | 09:07 PM
apprentice's Avatar
found the carnage
another quality part by dodge pic below ... so i need a flex plate and dont want to have to buy a starter to fit a second gen flex plate. what are my options???? also going to put in a new tq converter what stall do i want?? not much towing just the rig weight 8500# rolling . also how tight do i want it? 91% 88% are these real numbers or are they just pulling them out of there hind. dave said 650 + core , hughs is ??? dtt 950$
suncoast wants like $683.00 tq+
The billet flywheel with flex!
1989-07* 5.9L Cummins
Part No. 618-BFP
Price: $475.00
what to do ????? who to choose??? i need to order tomorow morning
Old Oct 13, 2008 | 09:36 PM
BC847's Avatar
1st Generation Admin
You don't have to guy a different starter to work with a 2nd gen flex-plate.
The only difference in the two is better materials and construction.
Old Oct 13, 2008 | 09:40 PM
apprentice's Avatar
bc what are the chances you have a part number ? ever time i goto cummins they want a serial number to look any thing up.
Old Oct 13, 2008 | 09:49 PM
apprentice's Avatar
3975464 ??? is that the number?
Old Oct 13, 2008 | 09:52 PM
bullfrog5.9's Avatar
cool pic put it in the carnage thread lol
Old Oct 13, 2008 | 10:01 PM
apprentice's Avatar
Flex plate
397-5464
Clamping ring
392-3049
Cap screws
390-8522
so that will cover the flexplate now a tq converter
feel free guys tell me how great yours is
Old Oct 13, 2008 | 10:05 PM
BC847's Avatar
I don't know the Dodge or Cummins number for the 2nd gen plate.
I run one like this (second down the page) http://www.americanhotrodsolutions.c...te_adapter.htm
Hope this helps.
Old Oct 13, 2008 | 11:18 PM
bigragu's Avatar
Originally Posted by apprentice
Flex plate
397-5464
Clamping ring
392-3049
Cap screws
390-8522
Ryan- get a new rear main seal from cummins while you are at it. Also, now is the time to replace any misc. seals that are leaking around drive shafts, transfercase, etc.
Old Oct 14, 2008 | 12:55 AM
apprentice's Avatar
honestly this is first vehicle i have ever owned that does not leak a drop. should i do it even if it does not leak? i am going to do the input shaft/ tq seal forsure
there was damage to the back side of the block nothing deep but i should be able to just feather out the high spots right?
any one have the pages for the rear main seal my service manual doesn't cover diesels
Old Oct 14, 2008 | 05:25 AM
AUGIE DOG's Avatar
Check the sticky's for part numbers! TC is kinda up for grabs. Call Goernds for suggestions. They are a great bunch of people and very helpful. When i upgraded to the 47rh i used an older style Dunrite that was used in large motohome applications. It was brand new never used and i did some horse trading for it. I just tow with mine approx. 6,000#'s Also look in classifieds for TQ some time guys are upgrading. Hope that helps. Also BC is right on the 2nd gen flex plate no starter change.........Augie
Old Oct 14, 2008 | 09:17 AM
unixcowboy's Avatar
Hope this helps.
BC --
I'm getting ready to put in a 47RH - '94 model LU - and was told the flexplate you have will not work correctly ( after I bought one )...I was told it shoves the TC too far back in the bellhousing.
DO you still have your 46 or have you a 47?
Old Oct 14, 2008 | 04:39 PM
BC847's Avatar
Originally Posted by unixcowboy
BC --
I run the original A518 (non lock-up converter) that came with my truck. The flex-plate I run is for all intents and purposes identical to stock/OEM for my truck.
Yes, the SFI plate I now run is a bit thicker than OEM, and I've read at least one reference to somebody shimming to compensate for it, but in my install, it was a direct swap with no adjustments. To my knowledge, there are no problems.
Outside of the A518 I've laid hands on, I have no experience with any other Dodge truck transmission other than what I've read in these forums.
Old Oct 14, 2008 | 04:50 PM
dieselJon's Avatar
Dave is right on the money. DP mag's Rustbucket got one put in and they said it did much better.....
blackram2500
Apr 29, 2010 04:36 PM
powerwagon440
Nov 10, 2004 11:59 PM
Gypsyman
18
Oct 2, 2004 11:59 PM
J.R. Adkins
Jun 16, 2003 07:57 PM
Monty
Jun 9, 2003 09:23 PM
