Fluids
Fluids
Ok i know this is the ye old question but im looking for some recommendations lol 92 12 valve 5spd (getrag) 4x4 130,000 miles.
What fluids and filters to use? Oil n fuel
What fluid to use for the trans and tranfercase?
What fluids to use in the rears? Dana 60 posi (rear) and the front i wanna say is also a 60
Power steering fluid? Transmission fluid im assuming like all the old pumps?
Anitfreeze 70/30?
Anitfreeze 70/30?
I use Fleetguard filters which I get from Genos.
My Getrags are filled with Mobil 1 5W-30 and over filled a quart.
The NP-205 T-case the Dana 60F and Dana 70 rear I fill with gear oil, and the weight could depend on the temps you plan on running the truck in.
The rest is pretty straight forward.
Itd be all year round more less and i live in the north east. With my rear being a posi still need the additive correct? U rund straight antifreeze?
On all my vehicles I try to use OEM filters, I buy Fleetguard from Cummins for my Dodge. If I can't get OEM, I'll settle for Wix or Purolator as they look, to me, as a decent quality aftermarket product, unlike Fram or department store brands.
Your limited slip diff. Will require the additive if you use standard gear oil. I use And oil extreme gear which has the additives in it already, so no extra additive is necessary
I use Baldwin or Wix filters. Engine oil I use chevron delo, 15w40. Tcase, front and rear diff, is schaeffers full syn 75w140, getrag is schaeffers full syn 5w30 1 quart over full. Antifreeze is chevron 50/50.
Srigs
Aug 7, 2003 06:29 PM
Max
May 20, 2003 10:02 PM
