flow max lift pump by BD???
I got the new diesel power magazine the other day and read the article about the BD flow Max lift pump anyone own one and if so what's ur thoughts on it??
1st Generation Admin
IMO, you'd get more than ample fuel for most applications with a regulated Walbro 392 for a LOT less money. The left over money could take care of upgrading the fuel plumbing and then some.
^ What he said.
I have about $200 into my setup and thats not counting recuperating some costs from buying 2 pumps.
I bought a Walbro GSS392 and a 340 (in-tank pump for mustangs) for $80 off of Ebay. I also bought a pressure gauge for $15 shipped. Then I bought a Mallory 4307M regulator for $108 shipped. Now add in about $40 worth of fittings, wiring, and fuel line and VIOLA! That's the setup.
Also the Flowmax puts out 20psi, which would require a locktite/snap-ringed IP shaft seal or a regulator.
I could NOT find anything cheaper (new that is) then the Mallory that could regulate down to the desired pressure.
how do you get it to 18psi, justramit? It said regulated 3-9psi, so I thought only 3-9psi gets through. The one I have is a 4-25psi. So when I rebuild my spare pump with 14mm H&R, snap ring and locktite the front seal, it will get 25psi.
1 Post
its not on yet, but they guy at the local K&G speed shop told me to loosen the lock nut and back out the allen key some more and it will let more fuel through. Its made for carb. applications so its set between 3-9psi but you can get more out of them.
nasty01cummims
04-02-2009 01:49 PM
nel76914
02-22-2009 07:25 PM
8mpg
05-22-2006 01:35 PM
