Fleet gaurd filters
Fleet gaurd filters
Where do you guys buy your fleetguard filters at, i have tried all the parts stores around here and none carry that brand. Trying to do the FS1221 fuel filter swap.
Case IH filters are a little less costly, I don't know who supplies them, but the one here in McCook carries Fleetguard, so that's what I got.
Most parts store filters (mobil, fram, etc) only have 6 small holes in the base for oil flow, Baldwin, Case, and Fleetguard have 8 larger ones. That's on the engine oil filter.
Received 1,637 Likes
I get Fleetguard from Geno's. BTW, all of the following are $1 or $2 more through the aforementioned Ryder Fleet Products. Just wanted to point that out.
Oil:
Stratapore LF16035 - $12.95
http://www.genosgarage.com/prodinfo.asp?number=LF16035
Standard LF3349 - $8.95
http://www.genosgarage.com/prodinfo.asp?number=LF3349
Fuel:
Standard FS1232 - $11.95
Air:
Standard AF4555M - $25.95
http://www.genosgarage.com/prodinfo.asp?number=AF-4555M
Oil:
Fuel:
Air:
Oil:
Fuel:
Air:
Oil:
Fuel:
Air:
Jimbo,
Ryder has the FS1221 for $12.47
http://www.ryderfleetproducts.com/ryder/af/ryder/core/content/product/srm/key/V52%20FS1221/pn/Fuel-Filter-Separator/erm/productDetail.do
Geno's has the FS1221 for $12.47
http://www.genosgarage.com/prodinfo.asp?number=FS1221
Either way, I'm sure if you order a case they're being drop shipped anyway.
Difference would be your shipping cost, I guess.
The OP wanted the longer filter
BTW
Thanks for the Links. I don't buy much from them, but I'll keep them in mind for the next order
Jimbo,
BTW
BTW
I buy from Geno's often and was just passing on some info. Geno's shipping cost, for anything, is $10 or $11 and is pretty quick. From Georgia to me takes only 4 days.
FWIW,
Ever since I put the longer FS1221 filter in, my truck not only runs better, but that low idle issue is much less noticeable. Can't explain why, but the 85 plus degree days are starting again, and the truck doesn't seem to have nearly as much bobbling going on in the heat.
T.
T.
Bulldozer
03-07-2003 11:32 PM
DieselDaze
0
03-05-2003 11:29 AM
