Fixed Bad Stock Steering...
Old 12-07-2009, 08:45 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
The joints are available from Speedway motors
This is the joint I used
http://www.speedwaymotors.com/Speedw...ound,6632.html
Here is the shaft I just put together this weekend
Old 12-07-2009, 08:47 PM
93flatbed's Avatar
I've gotta ask....What's the chain for?
Old 12-07-2009, 08:54 PM
I knew someone was gonna ask about that.
Keeps from tearing up motormounts when pulling
Old 12-07-2009, 08:57 PM
93flatbed's Avatar
That's what I thought but I still had to ask!
BTW. nice Shaft (steering that is)
Old 12-07-2009, 09:02 PM
Thanks
Old 12-07-2009, 09:04 PM
If people want to look elsewhere for the joint the shaft diameter and spline count is 3/4X36spl -3/4 round
Old 12-07-2009, 11:49 PM
95ram's Avatar
pulltilborke, did you just weld that onto the stock steering shaft?
Old 12-07-2009, 11:59 PM
Yes, The shaft I used was out of an 86 gasser. It was 2 1/2 inches longer then the original shaft off of my truck.
The gasser shaft measured 19" from the column side of the rag joint with the rag joint still installed to the spot where the shaft necks down, whereas my original shaft measured 16 1/2 from the same points of reference.
I cut the shaft at 18 3/4 and the shaft side of the yoke is at 17 3/4(where I welded it)
Old 12-08-2009, 02:10 PM
95ram's Avatar
Thanks pulltilbroke. I'll have to order a couple of these up for my cross over steering setups. It'll be a lot cheaper then buying a borgsen (sp?) shaft.
Old 12-09-2009, 12:48 PM
BRUISER's Avatar
well crap I guess I need to update the pics..
Old 12-14-2009, 08:01 AM
Pics fixed.
Old 02-01-2010, 05:31 PM
Albernikid's Avatar
Borgeson Part Number # BG940 Kit is supposed to come with the shaft Joint and necessary H/ware. Local parts supplier just quoted me $241.99 Ouch.
Old 04-12-2010, 02:19 PM
lenuelmp23's Avatar
so will this work with the OE steering shaft on a 91? just cut the stock end off and weld the ujoint on?
Old 06-08-2010, 09:24 AM
torqmonster's Avatar
Subscribed, my 93 needs this fix bad!
Old 06-08-2010, 04:49 PM
rustydeeretech's Avatar
where did you find the u joint? im looking for one thanks
Quick Reply: Fixed Bad Stock Steering...
