First Gen Fuel Gauge
Old Jan 31, 2007 | 10:05 PM
DieselSmith's Avatar
Why does it seem that, no matter how I drive, my fuel gauge seems to move to the halfway mark MUCH faster than the rest of the tank? Its not like its accurate to begin with anyways, but is there a fix for this? common problem? please its annoying!
Old Jan 31, 2007 | 10:11 PM
bgilbert's Avatar
It's a Dodge thing.
Old Jan 31, 2007 | 11:03 PM
Underpsi's Avatar
Mine takes much longer to go from half to empty then full to half.
Old Jan 31, 2007 | 11:21 PM
tomd's Avatar
Same here. The funny thing is how the last quarter seems to last longer than the first three.
I love that last 1/4 tank.
yeah, I know... keep it full.
Old Jan 31, 2007 | 11:24 PM
ofcmarc's Avatar
I had one that wouldn't move off full for at least 100-125 miles the it seemed that it gained speed on the way down.
Old Feb 1, 2007 | 12:21 AM
squirrel's Avatar
I always thought it dose that because of the way the tank is shaped.
Old Feb 1, 2007 | 08:16 AM
ScottT80's Avatar
Okay... so those of you that run it a little low... how long do you have to go once the low fuel light kicks on?
Old Feb 1, 2007 | 08:29 AM
DennyT's Avatar
For about 3 months now Ive been depending on the low fuel light. I know it usually works the other way. My gauge works good till about 3/4 of a tank and then it does what it wants to. It will make diesel then take some away. I go until I hit 325 on the trip and then give it some fuel. Need to get this fixed though. Im guessing that since the low fuel light is working the sending unit is good which would make the guage bad. Looks like I need to bust out the soldering torch.
Old Feb 1, 2007 | 09:15 AM
DodgerDoob's Avatar
I've gone at least 25 miles down the Interstate with the light on. I used to also keep track by mileage but now my odometer quit working. Someone said on here once that the light comes on at 5 gal. Don't know though.
Old Feb 1, 2007 | 09:31 AM
holeshot440's Avatar
If I got fuel as soon as the light came on, it would take 22 gallons to fill it (30 gallon tank.) That was my first 1st Gen, a '93. I haven't seen the low fuel light come on yet in this one I just got--probably doesn't work, like the 4x4 light.
Old Feb 1, 2007 | 09:37 AM
EClancy's Avatar
jeez, at least your fuel guages work
Old Feb 1, 2007 | 09:42 AM
2stroke's Avatar
i thought it was 7 gal.?
Old Feb 1, 2007 | 11:36 AM
DodgerDoob's Avatar
I just read it on here, I don't know.
Old Feb 1, 2007 | 05:40 PM
The first (and last) time my low fuel light came on I was able to put 29 gallons in a 30 gallon tank. That's cutting it a bit too fine for me.
Old Feb 1, 2007 | 06:10 PM
squirrel's Avatar
DennyT I had the same exact problem with my truck. I pulled out the sending unit and cleaned the contact points. I also noticed that by pushing on the float arm i could get the contact points to separate. So i bent them so they would stay in contact. Now the gauge works just fine.
