Filter Head???
Old May 13, 2009 | 10:32 PM
soggy's Avatar
Filter Head???
I'm building a fuel system, using the A-1000. I want to bypass the stock filter setup and get a new filter head/base with a big filter. Where can i find such a thing?
Old May 13, 2009 | 10:36 PM
Boatnik's Avatar
RACOR, They make filters for some very large engines. If you are close to a marine supply store they can help or just do a google.
Old May 14, 2009 | 11:07 AM
soggy's Avatar
Thanks boatnik, I'm looking for something a little cheaper, since I am a (ahem) thrifty 1st Gen owner, any one know where I can get a big rig setup for a little cheaper?
Old May 14, 2009 | 11:14 AM
apwatson50's Avatar
You need these:
That setup there cost me with filters ~$60, I got them at my local donaldson distributor, but a farm and fleet store will have them. Also can find them online lots of places.
Aaron
Old May 14, 2009 | 11:41 AM
bgilbert's Avatar
You can see my setup here: https://www.dieseltruckresource.com/...8&ppuser=33726
I don't have the part number for the Fleetguard filter head I used. A search possibly could bring one up or the place you buy the filter at can find a filter head for it. The long filter, which I think is pictured is Fleetguard FS1000. I had problems with it coming too close for comfort with the dyno and the trailer. So I switched to the shorter version, FS1212. Baldwin and Donaldson both have replacement filters for these two and sell filter heads for them as well. It's simply a 1" 14tpi filter head.
The one I used uses -10an o-ring sealed fittings.
Old May 14, 2009 | 01:13 PM
BearKiller's Avatar
You can get a dual-filter primary/secondary filter set-up off any junked big truck, probably just for the asking, providing you ask nice.
The advantage of the ones off the big trucks is usually the replacement cartridges are easily available and good FleetGuard replacements cost much less than they do for many of the specialty units.
On my personal truck, I have had excellent success using a GoldenRod ahead of everything else; it strains all but the finest stuff, thus vastly prolonging the life of the rest of my army of filters.
Old May 14, 2009 | 02:47 PM
soggy's Avatar
Thanks guys, BGilbert, do you have any other advice for this fuel system?
Old May 14, 2009 | 03:39 PM
bgilbert's Avatar
Make sure you have at least 5/8" or -10an/jic supply to the a1000. Out of the a1000 you can run just about any size line you want. Some have used 3/8, some 5/8". I used 3/4" bottom fed to the a1000, 5/8" to the bypass regulator, 3/8" to the inlet of the VE. 1/2" out the bypass regulator to the tank.
Old May 14, 2009 | 05:47 PM
Boatnik's Avatar
Now you are sounding like me. I prefer to spend less and get more. But, if it comes to spending other people's money I can go top dollar. If we were all honest I would wager that some of us really like our trucks but would "off the record" like a new one.
Old May 14, 2009 | 06:53 PM
AUGIE DOG's Avatar
Bill,did you tap into the bottom of your plastic stock fuel tank? If so, from your photo's you are routing to the fuel pump (red contraption) then to filters and IP. May I ask what was the purpose of doing that if that is indeed what you did. I think I know the answer but I'll wait to hear yours.
Old May 15, 2009 | 08:31 AM
bgilbert's Avatar
The a1000 prefers to be gravity fed.
Old May 15, 2009 | 10:20 AM
soggy's Avatar
Yep, I'm just waiting on my sump now to get started
Old May 15, 2009 | 04:23 PM
soggy's Avatar
What fittings did you fellows use to get a 3/8 feed line to the VE? I'm talking about coming out of the pump.
Old May 15, 2009 | 04:57 PM
M12 to -6 AN is what you want. GDP and Vulcan have them, and I think Summit and Jeg's do too.
Old May 15, 2009 | 05:32 PM
soggy's Avatar
Thanks Wanna, I'm getting them from Vulcan since they're pretty close to me.
