exhuast leak
Old Dec 25, 2006 | 11:16 AM
charliex25's Avatar
exhuast leak
Have an exhaust leak and have had it to two shops and they cannot find it. The problem is that it only leaks when it is cold and when it is stoped and ideling. When it warms up it doesen't leak . Any ideas? Is there a so called donut in the connection ? I am in Amarillo tx. on my way to the Baja for a month . Thanks a lot for the info to get my truck ready for the trip ( 6000 mi ) I turned the pump up one turn and it made such a difference that I can't believe it. ( I pulling a fith wheel ) Thanks again guys.
Charliex25
Old Dec 25, 2006 | 12:40 PM
John Faughn's Avatar
Go to one of the parts houses that sell some tools also , look for a stethiscope with a rod & diaphram on the end of the hose , good for finding noisy parts , for exhaust leaks , take the rod & diafram off , put a 1 ft. piece of tube on the end of the hose , use that to find leak touching around all seams / connections .
Old Dec 25, 2006 | 12:56 PM
BC847's Avatar
1st Generation Admin
Or you can just take a piece of some hose and with the engine running, with one end to your ear, take the other end and movie it around the exhaust manifold, turbocharger, and down-pipe. You should be able to hear it.
Old Dec 25, 2006 | 07:14 PM
charliex25's Avatar
donut
Thanks a lot for the info and I will not be on line for a few days as I am traveling west but does anyone know if they still use a donut in the exhaust system close to the manifold?
Charliex25
Old Dec 25, 2006 | 09:18 PM
BC847's Avatar
Originally Posted by charliex25
Does anyone know if they still use a donut in the exhaust system close to the manifold?
Charliex25
No donut's here.
Unless I'm very mistaken, all the exhaust down-pipes use the band-clamp type deal.
Old Dec 25, 2006 | 09:45 PM
loch's Avatar
Your right, no donut.
Old Dec 26, 2006 | 06:15 AM
charliex25's Avatar
donut
Thanks for thw info on the donut. ON THE ROAD AGAIN AND LEAVING AMARILLO BY MORNING Talk to you later. Heading to the Baha.
Charliex25
Old Dec 26, 2006 | 03:20 PM
keithplacervill's Avatar
if there is a leak wont it leave a black smoke trace because of diesel
Old Dec 26, 2006 | 07:16 PM
Boatnik's Avatar
Yep! especially if the fuel is turned up and you "drive it like you stole it"
Old Dec 26, 2006 | 08:13 PM
loch's Avatar
Is there anyone on the first gen forum that doesnt drive it like you stole it ? ok im guilty
dodgethis91cmns
Mar 30, 2008 02:17 PM
AKDSLDOG
13
Apr 17, 2006 09:04 PM
1320
Jun 23, 2003 08:05 AM
015speed
Apr 13, 2003 12:56 PM
