egt's
It would be nice to know what sort of temps and boost numbers you're running. Maybe you have a hole in a rubber boot on the pressure side of your intake. Maybe a hole in the intercooler. Both of those will result in higher-than-you-want EGTs.
For now, you can back out the fuel screw a turn or so. Less fuel = less heat. And yes, what size exhaust housing do you have? A larger housing will allow more air through and you'll see lower temps. Or you can rotate your fuel pin so that it is using a less aggresive profile...less fuel = less heat.
Or go the way the big boys do: Water Meth Injection.
my #s are 25 psi 850 post if i dont floor it i 105 w/ it floored have a 21cm housing that i will change later but i am going to tow a 26ft inclosed trailer w/ my other truck in it. i dont tow often but i need it cooler for the weekend any thing will help
thanks joe
thanks joe
If you are seeing 1050*F you're ok to go...just watch your water temps is all....if they start to climb then ease back out.
You may find that the AFC cone is the culprit for you. Normally when the cone is ground you don't have too much left that could be called the "lean or min." side...if you do, then rotate that first and try it.
What you will find is it will reduce the rate of fueling increase per pound of boost...not so much the amount but the RATE that fueling increases.
Since you have the big housing you'll want to reduce that part of the equation...at least that's my thinking anyway....
BTW, the higher up you go (altitude) the more smoke an heat with less work for the effort due to the housing.
pb....
pb....
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
