Egt Probe
NPT is "National Pipe Thread". That's different than NC (National Coarse) or NF (National Fine). Anyway...the threads are tapered so the further you thread it together to tighter it gets...in a hurry. You can get a tap at most hardware stores.
NPT rule of thumb...
run tap in till 5 threads left ABOVE surface (5 threads on tap remaining)
There are NPT reamers that add the taper to drilled hole prior to tapping, Not required on smaller sizes but they do ease the effort and improve the threads.
another trick to reduce chips falling into manifold, is to coat tap well with grease, and back it up frequently to get a better thead (especially important with cast iron, as chips are crunchy and can jam up the works (potentially breaking tap on removal))
tomd
Dec 12, 2006 10:56 PM
