EGR Rear disc brake conversion
I was looking for some steel braided brake lines and found Circle Track supply here on DTR.
Yes they have kits, but while there why not look at what else they have and I found that they sell a full rear disc conversion kit that doesn't require welding
https://www.circletracksupply.com/eg...ucks.html?cat=
Anyone ever install one?
Looks pretty legit.
Looks pretty legit.
Looks pretty legit.
Looks pretty legit.
https://www.dieseltruckresource.com/...-brake-326123/
One of the best moves I have made...Mark
Remembering back, some of the drivers of the old Eldos quit using the e-brake because the automatic release which released the brake as the transmission selector went into any gear sometimes quit working and they didn't know how to use the manual release...It was vacuum operated and usually fixed with a 6 inch piece of vacuum tubing...The victims who couldn't release the brake ended up having the car towed to me to fix, and were afraid to use the brake again, hence the subsequent stuck caliper at the next state inspection...
...Ben
Yeah, they are definitely a different animal. I once posted on a different forum that one needs to use the p-brake in order to adjust the brakes. I was flooded with "calipers are self adjusting" comments from people that didn't know anything about these calipers. Once you get them adjustment right, like I said, these will stall the Cummins. Once I had them adjusted, I haven't touched them since...Mark
dieselcarpenter
Dec 31, 2007 04:51 AM
