Ecm?
Ecm?
ive been tracking down this CHK ENG light source for quite some time now. 41! is the bain of my trucks existance. a few people have told me that the brain could be faulty
my only symptoms are flickering lights and jumping gauge in dash. and the check engine light. 41 = alternator field not switching properly. what exactly does the ecm do on my truck anyway? thanks in advance
Seva
my only symptoms are flickering lights and jumping gauge in dash. and the check engine light. 41 = alternator field not switching properly. what exactly does the ecm do on my truck anyway? thanks in advanceSeva
More likely bad brushes in the alternator or a bad connection. The PCMs don't fail very often and when they do the symptoms are weirder.
In your situation, the absolute first thing I would check is the mian body ground on the core support by the battery.
already put new alt in and voltage regulator. ill try the good ground next. i have a getrag so no tranny control. i looked at the ecm and it was hanging by one screw, i took the cover off and the gel was very dry and cracked looking. thanks again
forgive me
is the core support the front of the truck basically, where the headlights and grille attatch? if so then no!
as it turns out that little wire was broken off. i reattatched it and my lights seem to have evened out as well as my gauge
of course i still cant figure out the chk eng light. thanks for the ground tip. ill catch on some day
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
