Dumb Question #18791827350139841
Old Oct 28, 2006 | 11:26 AM
mhuppertz's Avatar
What is the solenoid on the side of the pump for? The connector broke on mine and nothing happened....
I just found it, KSB? cold start solenoid. What does it do???
Old Oct 28, 2006 | 11:41 AM
JD730's Avatar
Advances the pump timing around 5* when the solenoid is powered via a thermal switch in the intake.
Old Oct 28, 2006 | 12:04 PM
Boatnik's Avatar
THe only "Dumb guestion" is the one that you didn't ask.
Old Oct 28, 2006 | 02:47 PM
mhuppertz's Avatar
Is it an additional 5deg over the full advance of the pump? If it is I could wire it to a hobbs switch to activate that solenoid at 20 psi or so.
Just a thought...
Old Oct 28, 2006 | 03:20 PM
JD730's Avatar
Just a thought...
Doesn't quite work that way, full advance is full advance and activating the KSB at full advance won't to anything usefull. What it does is increase the internal pump case pressure which intern pushes the timing piston further in the bore. Its usually a bad practice to use the KSB for additional timing, it could compromise seals and usually burns out the solenoid if used for lengthy periods of time.
Old Oct 28, 2006 | 04:37 PM
mhuppertz's Avatar
It appears to be the same solenoid design as the fuel cutoff solenoid which is a continuous duty unit. But if it doesn't buy me any extra timing I can forget about it. It was just a though. I really need to pull the pump apart and shave that piston down a bit.
Old Oct 28, 2006 | 06:25 PM
gman07's Avatar
So on the intercooled trucks the solenoid should have voltage when intake temps are low and the key is on, right? I checked mine one morning just after I started the truck and had 0 volts (probably about 40*F).
Old Oct 28, 2006 | 06:35 PM
That's correct. That's the wrong way to check it, though. If the grids were working then the switch may have been too warm. Same issue if it was plugged in. The best way to check it would be to disable the grids by pulling one of the coil wires off each relay, then turn the key on and check for voltage at the KSB.
Old Oct 28, 2006 | 09:42 PM
gman07's Avatar
Thanks for the tip, I'll try that just to make sure it's working.
calvin
Jan 4, 2003 10:41 AM
TPilaske
Jan 1, 2003 12:57 PM
Push Rod
Dec 31, 2002 10:46 AM
wheels
Dec 22, 2002 10:49 PM
bigbaddiesel
Dec 7, 2002 07:40 PM
