Dual fuel
Old Mar 16, 2012 | 06:08 PM
Moparbubba's Avatar
Works great holds a steady 10psi at idle vs a bouncing one with the fs1221 cant pull it down lower then 3psi at wot
Old Mar 16, 2012 | 06:11 PM
Moparbubba's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 16, 2012 | 08:15 PM
enafzige's Avatar
Looks great! Good job!
Old Mar 16, 2012 | 10:02 PM
Moparbubba's Avatar
I gained more then 1 psi at wot now its at almost 5psi instead 4ish. And it lets you pivot the filter to clear the lift pump no issues with throttle linkage. I already had a fuel heater delete and fs1221 done so just remove the filter and spud (fuelheater if you had one) install the longer spud and nut into the filter head then the adapter and holding nut fill and install your water separator and filter crack open your bleed give the lp a pump and its good to go
Old Mar 24, 2012 | 12:57 PM
Moparbubba's Avatar
Heres vids if ole shakey with the ofi lpplp and dual fuel
http://www.youtube.com/watch?v=ifJRb...1&feature=plcp
http://www.youtube.com/watch?v=HTw8G...2&feature=plcp
Old Mar 24, 2012 | 07:31 PM
BILTIT's Avatar
So this will not work with the fuel heater?
Old Mar 25, 2012 | 08:53 AM
Moparbubba's Avatar
Yes this deletes the fuel heater
South Bend Clutch
South Bend Clutch
13
Dec 4, 2012 09:51 AM
GotStacks
May 23, 2009 12:08 PM
RDR
27
Dec 23, 2008 07:34 PM
DNRCustoms
Nov 11, 2008 08:25 PM
Timberman
Feb 5, 2007 12:13 AM
