Driveshaft questions
Old Mar 21, 2011 | 06:41 AM
CFPoobah416's Avatar
Hey guys i have a 1993 reg cab 5 speed 4x4 and i went to the dillsburg dyno day and my 4th pull i layed down 350 hp and 755 lbs of torque at 3500 rpm and 121mph wheel spd and at that time my rear drivehaft blew in half ! so now i need a new driveshaft and i was curious cause there are no reg cab 4x4 cummins around me only 2wds and i was curious if there driveshafts would fit on mine ? or any other ideas or solutions would be great ! thanks CJ
Old Mar 21, 2011 | 07:23 AM
chaikwa's Avatar
Why don't you just have one made for what you're doing with the truck? Then you won't be going thru this every time.
Old Mar 21, 2011 | 08:26 AM
simplysmn's Avatar
C J I would build 1 that way you know what you have and it's made to fit what you are going to do with truck and maybe it won't break ? easier in long run
Old Mar 21, 2011 | 10:33 AM
Thanks guys
Old Mar 21, 2011 | 12:55 PM
TIMMY22's Avatar
2WD is different than 4WD.
2WD is a 2 piece w/ carrier bearing.
4WD is 1 piece from the transfer case to the rear end.
Ramdriver15
Sep 27, 2009 01:21 PM
Nsomniac05
Jun 11, 2009 07:20 PM
SjLingenfelter
Jul 20, 2004 07:41 AM
