door locks
door locks
ok i am trying to figure out my power door locks they dont work at all the passenger side was working still but now it dont work either they dont click or anything i have seen quite a few like this and am just trying to fix it i have cecked the fuse box under the dash and all fuses are good just wondering if anyone had any other ideas on what it could be thanx
I have had a couple of dodge trucks with power locks and all but one of them had the lock mechinism in the door go bad. Remove your door panel and locat the locking mechinism, it will be bolted with two 10mm bolts to the lower out edge of the door. Disconnect the rod that goes from the mechinism up to the part that keeps the door closed (can't think of the proper term) then see if you can move the electric lock up and down if not you have a bad mechinism. You could also try to put power to it and see if you can get it work that way.
Hope this is some help.
Ryan
Ryan
There is a connector assembly inside the door. Usually the driver side will jar loose or just get dirty clean the connections and reassemble then see if things work. If driver side has a problem then so will the passenger side as the passenger side gets its juice from the drivers side.
nomad65
Aug 20, 2007 06:01 PM
Bradtothebone
May 21, 2003 10:31 PM
