Don't shoot me, Please
Old Jan 19, 2005 | 10:15 AM
92DIESEL's Avatar
I know I SHOULD be able to do this by myself, But...
Can anyone tell me how to change the headlights in these trucks?
It does not look like there is enough clearance if you dont take of the grill.
I need to know 'cuase I got a ticket and need to get it changed and show the cops by 4:30 today in order to get rid of the ticket. and I'm at work, so I can't fool around with it.
Thank you in advance,
Michael
P.S. dont yell at me too bad.
Old Jan 19, 2005 | 10:22 AM
jiMMyCTD's Avatar
squat down and look inside, youll see the adjusters. back those out all the way and it should fall out. mine did anyways! jiMMy
Old Jan 19, 2005 | 10:55 AM
Dan Brooks's Avatar
There is a trim piece around the headlight that is held in place by two screws - Chrysler calls it the "headlight door" - it looks like it might be part of the grille but it isn't.
Once the trim is off, you can get to the four screws that old the stainless steel "ring" around the headlight, and it will come right out. No need to mess with the adjusters at all.
Old Jan 19, 2005 | 11:00 AM
jiMMyCTD's Avatar
ahh, yes that is what it is. been a while since i had mine out. jiMMy
Old Jan 19, 2005 | 11:04 AM
AbertaRAM's Avatar
This is how I change a headlight, Frist you remove the 4 torx screws out of the plastic headlight cover, then you can get at the 4 screws holding the crome cage that holds the light in. You may have to drill the heads off the screws holding the cage on, they can be rusted in, once the light is out you can get a hold of what is left of the screw from the back side, unplug the light, then install in reverse order, using new screws and a never seize so you can get them out again at a later date.
Old Jan 19, 2005 | 11:44 AM
92DIESEL's Avatar
Thank yo very much!!!! I'm going on lunch now to try.
I'll let you know how it works out.
Michael
Old Jan 19, 2005 | 01:05 PM
92DIESEL's Avatar
Yeah, Something actually work the first try
All went smooth except I dropped one of the screws that hold the plastic trim ring into the snow. But I can replace that.
And the best part is that they both work!
Its a first,
Thank you all again,
Michael
Old Jan 19, 2005 | 01:25 PM
Redleg's Avatar
That screw will soon be secured in your tire......
Old Jan 19, 2005 | 01:54 PM
92DIESEL's Avatar
I like your optamism
Old Jan 19, 2005 | 06:32 PM
Denis's Avatar
I just replaced one of mine. If you look at the grill around the headlight, it should have an insert that is held in by two screws, one to the left and one to the right of the headlight. THey hold this insert to the grill itself.
Undo those, and you'll see the headlight is held in by a metal frame screwed in 4 places to the mounting bucket/adjuster plates. Take those 4 out, and there you have it!
Old Jan 19, 2005 | 06:33 PM
Denis's Avatar
Oh, sorry, I see everyone answered! For some reason, none of the replies showed up until after I submitted my reply. Odd.
Old Jan 20, 2005 | 07:33 AM
92DIESEL's Avatar
Thanks Denis, It all worked out fine- I got rid of the ticket
Old Jan 22, 2005 | 05:39 PM
Denis's Avatar
Excellent!
Nicheshok
Jun 12, 2012 09:30 AM
ASHNBAK
Jul 29, 2009 10:22 PM
dadsrig
Jan 8, 2008 11:52 PM
satburn
Dec 2, 2006 01:18 PM
y-knot
Nov 6, 2003 12:45 AM
