Does having a modified fuel pin make starting harder in the winter?
was just wondering...
If mine sits for a day or more it's kind of hard to start and when it does get going it smokes like a chimney. I was wondering since a modified fuel pin gives the motor more fuel when the motor is not under boost, the extra fuel might be making it harder to start and run when cold.
I might go back to the stock fuel pin to see.
how cold are you talking? I know mine at minus -25c to -30c smokes till it warms up even plugged in and i know I don't have air leak ... mine starts without being plugged in till -20 c no prob it does sound like it has a big block cam in it , I try not to do that but if i have to i will. Are you grid heaters working ? I also see you have An asa Mod ,I noticed i get more smoke this year when starting cold since I put mine on too plus you are pushing big fuel with those sticks ,DDP 80 HP
Don't replace the block heater without making sure it's not just a bad cord. The heater cord will go bad more often than the heater itself.
i just had to put a wolverine oil pan heater on and i messed with my cord and yes check it. mine is on its way out but got it working for now i cant find any splits in the block heater cord but i will assume it is the original cord so time to change it
trailinone
May 29, 2011 07:15 PM
zethtays
22
Dec 10, 2009 11:35 PM
dieselcarpenter
Feb 3, 2008 01:46 PM
