do away with the fuel heater
Old Mar 7, 2010 | 04:06 PM
gozapper's Avatar
My fuel heater got to leaking around the gasket, so in the prosess, I damaged it while trying to do the two locknuts system to remove the
stud and somehow damaged the fuel heater itself.
I would like to do away with the heater completlely.
Can I machine about 1/4 inch off the end that screws into the intake manifold?
Has anyone done this?
Thanks, Tom
92 D350
Old Mar 7, 2010 | 05:59 PM
BearKiller's Avatar
Thanks, Tom
92 D350
Best is to go to CUMMINs and get the correct fuel-filter stud that is made to be used when the heater is eliminated.
I deleted the fuel-heater on my truck and haven't missed it since.
Before, a couple of times, it followed the fuel-filter off when trying to change a filter.
I didn't need this aggravation out on the side of the road somewhere, so I just got rid of it.
Another option is to by-pass the stock fuel-filter completely and route the fuel through a remote-mount filter located in a more easily accessible position.
Old Mar 7, 2010 | 06:04 PM
BearKiller's Avatar
And, by the way, just so others who might read this will know better :
The fuel-filter stud is made in either of two configurations.
One type is notched, or slotted if you will, such that a very wide screw-driver-type blade is used to remove/install it.
I re-ground one of those hexagonal cold-chisels into a dedicated tool for use on that type, using the appropriate sized wrench on the hex shank.
The other type is hexagonally bored and a very large common Allen-wrench is inserted in this hex bore to remove/install the stud.
Old Mar 7, 2010 | 10:36 PM
gozapper's Avatar
How did Cummins charge for the stud?
Old Mar 7, 2010 | 10:55 PM
BearKiller's Avatar
The correct part-number should be floating around amongst the threads somewhere, as this has been discussed a lot; it may even be in the "sticky".
It has been a while; but, I am thinking something less than twenty-bucks.
d zul
Dec 2, 2011 05:20 PM
Ramrod90
Feb 3, 2009 07:39 AM
Perkio
Apr 9, 2008 08:00 AM
taildragger
Dec 4, 2006 10:00 AM
csramsey640
Oct 7, 2005 05:25 PM
