DIY..vent window latch
Old Feb 8, 2008 | 06:47 PM
Kev_n_AZ's Avatar
A, B, and C all fit together onthe outside of the window.
W is window
D against inside of glass
E over D
F into D and E with groove closest to glass
G screws through F,E and D, into A
make sure taller part of F is pointing proper direction to allow latch to rotate proper direction.
I goes into J at 1 end woth point sticking out.
once A through G are installed and set correctly, insert I/J point into K with black point out.
insert K through L with snub end sticking out of latch handle. spring will stick out back side of latch.
place H over F on E and position L* on F.
hold tight to window.
press in M (roll pin) to lock patch to assembly.
test latch function for proper direction. you may have to loosen window assembly and rotate 180* for adjustment.
if latch is in wrong position, use small allen wrench or other item to carefully push roll pin (M) out to release latch from cam.
after adjusting proper direction, check that window closes, latches and locks. then make sure it opens again
L may not have a hole drilled in the end for K to protrude outward.
K is the release button that "locks" the latch in place when window is closed
Old Feb 8, 2008 | 09:11 PM
BearKiller's Avatar
Very good.
Now I gotta go out and look to see whether they came with a latch, or not.
You woulda thought I woulda already noticed a detail like that.
Old Feb 9, 2008 | 10:34 AM
Stickied.
Old Feb 10, 2008 | 09:15 PM
BC847's Avatar
1st Generation Admin
And the part numbers are . . . . . . .. ?
Old Feb 11, 2008 | 12:18 PM
PapeCAT's Avatar
cool! Too bad, only yesterday I just stopped by my local area 51 pick parts junk yard and spent 10 bucks for a whole new wing vent window/latch assy!!
No worries.
Caver Dave
May 9, 2007 01:15 PM
schoust
Apr 11, 2007 10:03 AM
oldblues
Mar 15, 2007 07:43 AM
Timberman
Dec 5, 2006 07:59 PM
subspd
Aug 27, 2006 02:17 PM
