Dim Right headlight
Old Mar 6, 2020 | 08:04 PM
rustydiesel's Avatar
Dim Right headlight
1993 D250. Right headlight is dim. On high beams even more pronounced. Daylight running lights are not running (truck is in Canada). Inside cab, right turn signal indication is partly illuminated, but not flashing. Otherwise signals work when called upon. Expect something pooched with daylight running lights relay...Uhm, where might I find that?
Old Mar 6, 2020 | 10:28 PM
edwinsmith's Avatar
Check the ground on your right light.
Old Mar 7, 2020 | 09:53 PM
As mentioned...grounds are often over looked and are essential. Find, clean (sand to bare metal) and install...if you can add a dab of dielectric grease it will help the connection last longer before any corrosion can get past to foul things up.
Daytime running light relay is on the pass side inner fender kind of in front of and below the washer fluid reservoir.
Old Mar 8, 2020 | 05:52 PM
Nope. Just a dim headlight and one of the two filaments was burnt out....and a dim operator.
brattboy
May 3, 2012 10:25 PM
stroker101
Jan 10, 2009 11:31 AM
propaneman
Jan 1, 2007 11:50 AM
