differential gear oil
Old May 23, 2007 | 07:51 PM
A_port93's Avatar
what type of fluid should i run in the dana 70 rear with lsd and dana 60 front?
Old May 23, 2007 | 10:40 PM
BearKiller's Avatar
I have several hundred thousand miles on several Dana 60 and 70 equipped trucks, all limited-slip, and have used plain old 85W-140 gear-lube of various brands in them with never a failure.
I did have a clutch grabbing issue, a few months ago; but, two tubes of that limited-slip additive stuff cured that problem.
Old May 24, 2007 | 12:38 AM
Ace's Avatar
Ace
I like the Royal Purple because it already has the limited slip add in it. 75w-90 is better unless you tow alot.
Old May 24, 2007 | 08:49 PM
If it's a tow rig, go synthetic in the rear. No need for it out front. If the truck is just a play toy I'd go for a lighter lube like an 80W-90. The axles never get hot enough to need the thick lube unless you are working it.
Old May 26, 2007 | 08:29 AM
timb's Avatar
Regular old 80w90 here for 370,000 miles without any problems.
West Coast
Nov 22, 2011 01:16 PM
Svenne
29
Jul 26, 2009 09:14 PM
apache1010
Mar 19, 2008 09:49 AM
leadpants
Oct 9, 2005 01:44 PM
