diesel showing up in oil
My dad has a 91 dodge that today lost oil pressure. We checked the oil and noticed diesel in the oil. After investigating further we realized diesel was being blown out of the breather hose. My question is did we just lose a gasket or did the injection pump go south.I appreciate any help I can get. Thank you.
Yep, it sounds like the lift pump diaphram let go, just like the ones on the old carburated Chevy small block. They would dilute the oil with gasoline, BANG!
Wanna said something about changing over to a piston style lift pump like what is on the second gens. only putting out lower pressure to prevent damaging the VE pump. Mine hasn't gone south yet so I haven't looked to far into changing it. Seemed to be pretty straight forward swap. Some of the sound insulation on the lifter cover will need to be excavated for it to fit.
Howdy,
Boatnik's right about both, the better pump is the piston pump...but you need to use the correct part number pump, not just any piston pump.
The cost is also quite a bit more than just a stock replacement pump too...here's the numbers and approximate prices. When I orderred mine it was a bit more...
Pump,Fuel Transfer P/N#3936320 $153.23
Gasket, Cover Plate P/N# 3639258 $1.75 ea (2 required)
Tube, Fuel Supply P/N# 3914753 $29.29
Spacer, Mounting P/N# 3914284 $10.40
Washer, Sealing P/N# 3963983 $1.00ea (2 required)
Hope that helps,
Vinny
Hope that helps,
Vinny
Originally Posted by runamuk
I find it very interesting that the same "diesel fuel in oil" would have been diagnosed as a leaking injector on the 3rd gen forums.
Rick
Rick
especially the ones with the pump in the tank.
Same thing with the 24 valve 2nd gens, is just mounted to the block, no path for fuel between them.
Only thing left is a leaking injector.
phox
GizmoJoe
Mar 7, 2008 10:34 PM
Sux 2B urTurbo
Jul 9, 2004 04:52 AM
Stevenc
Nov 21, 2003 05:59 PM
