Diesel Auto Power 6x13s?
Old Sep 7, 2015 | 09:25 PM
Vader93's Avatar
Just curious if anyone has ran these new 6x13 injectors by JKidd. I'm running 5x16s from DAP now and they sure run hot and smoke alot. Looking for something new but don't want to loose to much power. Any thoughts. http://dieselautopower.com/diesel-au...-ve6x13sac145/
Old Sep 8, 2015 | 10:48 AM
1972RedNeck's Avatar
I won't touch any injector that doesn't run Bosch tips.
Old Sep 8, 2015 | 06:55 PM
Vader93's Avatar
The ones I'm running now have Bosch bodies, how do you tell about the tip
Old Sep 8, 2015 | 08:23 PM
BC847's Avatar
1st Generation Admin
I went from a 6-hole nozzle to a 5-hole nozzle for the potential power improvement (see fine print).
- The idea is that, for the same volume of fuel injected, the 5-hole will result in a greater (deeper) piston-bowl directed penetration of the charge-air to occur during the injection event . . . . . . compared to the 6-hole.
Perhaps the 6-hole presents a cleaner burn, but for power, go 5-hole.
Fine Print: I made good WOT power (480something to the ground) with some Scheid 6x016 EDMs. Those being selected then, based on what other big power VE fueled engines were using.
The fact I've split two of those nozzles had me seek a less potentially engine destroying make/model.
My research led me to the information presented above. Take it for what it's worth. . . . . .. and perhaps they don't split as much with my application.
I've gone to a 5x018 that have been flow-honed stupid-bigger along with some other work. While waiting for more air, I've temporarily backed off the fuel-screw so as to match the "pull", of the former injectors. They run well thus far.
Have you considered spending said money on a turbo upgrade? Air to burn/support the wasted fuel (smoke/high EGTs).
Old Sep 9, 2015 | 04:31 PM
Vader93's Avatar
I'm running an HE351 and plan on adding an S475 to the air side
Old Sep 12, 2015 | 11:39 AM
cougar's Avatar
Once I figured out what I was doing wrong, my 7X.010" ran cleaner and cooler than the 5X.012" I'd been running for a long time. The power was a bit better also. The fix? Fuel delivery rate, aka fuel pin.
Old Sep 12, 2015 | 12:03 PM
Vader93's Avatar
So your saying i should ditch the afc delete and run a performance fuel pin instead
Old Sep 12, 2015 | 02:13 PM
BC847's Avatar
DOH!
Old Sep 12, 2015 | 11:59 PM
Vader93's Avatar
What's so bad about an afc delete. I know Denny T personally and all i can say is he is one of the brightest, most honest I've come across and don't believe he would make and sell a part that was not heavily researched and of the best quality
Old Sep 13, 2015 | 12:36 AM
ChrisLib's Avatar
See cougar's post above...it's about over fueling, iow too much fuel for the amount of air available.
Old Sep 13, 2015 | 12:45 AM
Vader93's Avatar
I understand it's too much fuel for the turbo i have now and i doubt the s475 I'm fixing to add to it will clear up the low end very much. My question was about anyone running 6x13s on a ve truck. I was just curious if anyone out there has any experience with these injectors as to the best of my knowledge they have not been out very long. I plan to keep the afc delete. I personally love it's functionality and appearance. Allows for easier access to several parts of the pump as well i think.
Old Sep 13, 2015 | 12:51 AM
Vader93's Avatar
I've recently adjusted my pump and modified my HE351 a little for more boost but my main concern with the 5x16s is haze at idle. The HE351 clears up very well and very fast once i get on the throttle. EGTs are relatively low now as well, even after a decent wot pull. Granted i have backed off the fuel screw a decent amount until i have the extra turbo to justify threading it back in a good way. On a side note, BC847, you've had some great write ups. I've got your valve spring post saved to my phone for when the time comes. Im holding off until i can do the springs, studs and pushrods all at the same time. If the money man will allow it.
Old Sep 13, 2015 | 11:03 AM
Dean Snow's Avatar
I've ran many different sets of dap injectors. All I can tell you is I've had big name big dollar injectors and dap perform the same if not better. For about half of the price.
Onemoparnut
May 23, 2013 10:01 PM
TDIDog
Aug 21, 2012 12:09 PM
Onemoparnut
Jun 14, 2012 07:20 AM
pwabbott
14
Dec 20, 2002 08:23 PM
