Diamond eye exhaust questions
Old Apr 2, 2021 | 08:22 PM
samiam4's Avatar
Good evening,
I just put my exhaust on my d250. I haven't heard it on the highway yet, but right off idle it's got a funky low sound. Not sure it's a rattle. Do others experience this?
It's an automatic and the space between the frame and trans line is close.
Oh, I was thinking of putting back my original dodge bellhousing mount. But it's missing the bolt. I'm using a gen rh47. Can some tell me if its metric and maybe a bolt size/length. I think I used the original gen1 hardware which might explain why the bolts were difficult =).
Bracket is low- but I'd feel better with a fwd support at the bell housing.
Maybe some running an fte resonator and muffler can comment on if that off idle noise dissapears??
I think it might be hitting the frame still.
Old Apr 3, 2021 | 05:28 AM
KRB's Avatar
KRB
Not sure if it's the same "noise" but mine had a odd sound when the pipe vibrated against the frame. It's tight & I had to keep adjusting. I split some rubber hose to put on the frame edge and added that in there to help.
Old Apr 3, 2021 | 09:26 AM
cougar's Avatar
I have a rattle at idle. Mine is from my loose running boards. Mine also had an odd whistle. Went away after I filed the wire edge off the inside of the tail pipe. I also have a 47RH. All the hardware went right back in its place no problem.
Old Apr 4, 2021 | 10:00 PM
samiam4's Avatar
Daylight was kind. Clamp was rubbing only off idle against the shock. No leaks, but I'm going to add the bellhousing mount back.
DOZENVALVE
Sep 12, 2015 10:20 PM
bradler
Jan 17, 2011 02:29 PM
artieb
Sep 21, 2010 02:39 PM
AJMartin0321
Jan 6, 2007 08:46 PM
LCH
Dec 7, 2005 08:01 AM
