Dana 70 rebuild: does this gear pattern look good?
1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
Typically I check everything and try to get it in spec as much as I can. Then I put everything together while in neutral I roll the vehicle back and forth. This would be the true contact pattern and is what you want. With those pictures above, I would guess the pre-load will actually fall inward a bit. BUT you never know, could toe in/out.
