dana 60 or dana 70?
Old Jul 27, 2011 | 03:59 AM
Brian.B's Avatar
dana 60 or dana 70?
how do i tell the difference in a dana 60 and a dana 70 rear end,,,,i have a chance to get one out of an 89 gasser 250 it looks just like mine..
Old Jul 27, 2011 | 05:43 AM
Onemoparnut's Avatar
It should be cast in the center section of the housing I think but a gasser would have a 60 unless someone swapped it out.
Douglas2's Avatar
hey-Hey!!!,
The D70 has axles that look like nails and do not have wheel studs on them. the D60 axle actually carries the vehicle load and the D70 has a hub with tapered roller bearings. The D70 axle only carries drive torque( vehicle load is carried through the hub ).
cheers,
Douglas
Old Jul 27, 2011 | 07:17 AM
Originally Posted by Douglas2
hey-Hey!!!,
cheers,
Douglas
I think you got things backwards there...
Old Jul 27, 2011 | 07:28 AM
Douglas2's Avatar
If you're a gambling man I sense a fundraising opportunity... But seriously, the D70 is the floating axle style, and the D60 axle carries drive torque and vehicle load.
cheers,
Douglas
Old Jul 27, 2011 | 11:51 AM
CaptainChrysler's Avatar
There are full float D60's as well.
They are probably even semi-floating D70's out there somewhere, too. Dana sold axles to all sorts of manufacturers.
Old Jul 27, 2011 | 12:44 PM
Douglas2's Avatar
So this would have been a fund raising event for somebody other than me...
cheers,
Douglas
Old Jul 27, 2011 | 01:34 PM
Brian.B's Avatar
i have owned a 86 w250 with a full floating dana 60 rear and an 87 d250 2wheeldrive with a regular ''what i call flat axle''dana 60 could that be what your thinking of,,would it tell you which axle on the door ,,or in the vin #
Old Jul 27, 2011 | 02:08 PM
furious70's Avatar
yup, 60 or 70 should be cast into one of the 'triangles' around the center section.
tankeryanker
14
Jan 19, 2005 04:18 PM
Mechanos
Jan 22, 2004 12:45 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
