custom radiator
Old Aug 30, 2006 | 12:36 PM
charliex25's Avatar
custom radiator
I am thinking of having a cross flow radiator custom built adding two more cores if posible. My question is do they make a top hose long enough to go to the other side of the radiator( at present both the inlet and outlet are on the same side of the radiator ) or would it be ok to leave it on the same side?
Thanks in advance,
Charliex25
Old Aug 30, 2006 | 01:30 PM
flashgordon's Avatar
Thanks in advance,
Charliex25
91.5-93 have the thurmstate upper elbo rurned, so that it point to the ether side. after you order that housing from cummin, all you have to do is order the upper radiator hose for a 91.5-93
Old Aug 30, 2006 | 07:52 PM
You could have them put a baffle under the hose fitting instead to force the water to flow more evenly. Wouldn't be hard with the tanks off for a recore.
8liter
Sep 22, 2012 10:19 AM
DarrellB
Aug 10, 2012 12:18 PM
AKDSLDOG
Mar 14, 2003 10:19 PM
tlea7
Mar 6, 2003 07:48 PM
Mostwanted
Mar 6, 2003 07:06 AM
