cummins swap issues
Old Dec 10, 2012 | 08:16 AM
12valvewagon91's Avatar
cummins swap issues
In this swap I did nothing to the engine but put a new cam in it, and adjust the valves. Everything else has 298k on them.
Engine starts hard after it sits, Needs primed up then it pops off every time. I air tested the lines I have made, all are tight. I ran the return line just up to the filler neck, and welded a bung in there so it just dripples back into the fuel tank.
Could it be losing prime if thats just in the air, I noticed I hear the fuel drain back after its shut off. Do I need to put a line from that bumg and have that line in the fuel to keep the siphon in the line?
Also I told the customer to drive it, and not all the bugs, Ill take care of them as they happen. He told me one time it wouldnt shut off, I told him to tap on the fuel shut off solonoid, Might be hanging up.
All in all he is happy, but were gonna have to address the starting issues.
Old Dec 10, 2012 | 09:12 AM
simplysmn's Avatar
I think your return line may be sucking air ? they go back to fuel tank reg ? I would think it's getting to the air easier and that's your problem ?
Old Dec 10, 2012 | 09:31 AM
Thats what I was thinking. I told the guy to put a 1/4" hose and a heavy duty nut wired tot he end of it to weight it to the bottom of the tank. That way it cant suck air. There is about 1.5" of 1/4" bung sticking inside the fuel fill neck, and it shouldnt be to tough getting that hose on there.
I still think he has a fuel shut off solonoid sticking also.
Old Dec 11, 2012 | 07:04 AM
jimlj's Avatar
I don't think the return lines draining into the filler neck are the problem. That is how I ran mine and have not had any problems for the past 40,000 miles. I recently got around to doing the rear tank, adding a selector valve to switch between front and rear tanks and route the return to the proper tank, and have not had any trouble with all my added connections.
I would check from the lift pump forward for a place air can be getting in,
themontajew
Sep 25, 2011 10:32 PM
themontajew
Oct 29, 2010 05:28 PM
badzj999
Sep 14, 2010 05:58 PM
thek0rn
Dec 14, 2009 05:48 PM
ILLINOISRAM
Jan 9, 2008 05:19 PM
