cruise & overdrive quit at the same time?
I have a 93 2wd. the cruise and overdrive quit working at the same time,but while still rolling at speed I can place trans in nuetral, turn off the ignition, restart the truck and both the cruise and od will work again.I've only had this truck about 6 months.The only thing Ive replaced is the ignition switch,which a friend of mine gave me used.any help will be greatly appreciated,
sounds like the PCM.
The clock spring is behind the horn (on the steering wheel) it enables to wires to go though the steering column without binding up. the horn and cruise wires go though it. A lot of times you will get a plastic on plastic scraping sound when they go bad.
Crank sensor is down on top of the crank damper, a little to the right of center. Make sure it's tight and that the gap is somewhere in the neighborhood of 0.050" using a non-ferrous feeler (folded over matchbook cover is close enough if you don't have brass). Then follow the wiring harness up the front of the motor, paying close attention to where the harness goes around the corner of the head. Also check the connector in the harness for corrosion.
If the PCM does not get signal from the crank sensor then it does not know the engine is running. So OD, cruise, A/C compressor, and charging system are not activated.
Yeah. the truck came with the 47rh I think. That might make it a true 91. But, this is my third trans I am bolting up. The first two were the orig, and a used. This one has ARI valve body kit and billet conv. I did the jump out the controller behind the glove box to a toggle to get it to OD. But I cant imagine I am just burning up transmissions. The guy who rebuilt the trans I am plugging into it used HD parts for the rebuild and set the bands for a firmer shift. I did everything right. If The toggle switch trick I have is sufficient, I wont press further. But I cant Figure out why I dont feel the lockup before OD. I can really feel it my 98' Feels like a fifth shift. So now that I got the rebiuld info out of the way, The question remains. Is the toggle sufficient or do I need to fix this before I smoke another trans? Thanks
