Creaky front end
Old Feb 13, 2005 | 12:06 AM
mhuppertz's Avatar
Creaky front end
When I turn my wheel I get some pops (like my knees). The alignment checks out as do the ball joints (king pins?).
Does anyone have experience with this issue?
Mark
Old Feb 13, 2005 | 09:52 AM
dodgenstein's Avatar
Probably the U-joints in the axle shafts binding. Try jacking up the front and turning the tires with the front wheels turned (hubs locked in). If you have bad u-joints you will feel them binding.
Old Feb 13, 2005 | 10:10 AM
dzpoorjr's Avatar
My truck was creaking and popping-was in a lot of water-greased all the fittings and it went away!
Old Feb 13, 2005 | 10:19 AM
spunbearing's Avatar
Mine does the same thing especially when I have my wheels cut left and am backing up then start straightening out. Replaced the draglink because it had a little bit of play.. same deal.
Rebuilt the driveline the steady bearing was shot anyways but still makes the noise. I lubed everything there is to lube. I'm putting new front springs on tommorrow so I'll check it out again. Wish I could find it.
Old Feb 13, 2005 | 10:48 AM
mhuppertz's Avatar
I'm starting to think I have some loose rivets on the frame. I wealded the brace by the steering box because it was moving and causing noise, but there might be other spots.
It makes me cringe every time I have to turn the wheel in a parking lot!
Mark
Old Feb 13, 2005 | 11:24 AM
Redleg's Avatar
Check the frame around the steering gear. It's prone to cracking.
Old Feb 13, 2005 | 04:20 PM
rebal's Avatar
the u bolts holding the springs to the axle will pop if you have oil or grease all over them and low tire tread and wide tires will make them pop(spring slipping) on the spring perches some times retightening them will stop it
Old Feb 13, 2005 | 08:15 PM
Den's Avatar
Den
Mine did that on with the wheel turned to the left pretty far. It would make a creeeking/crunching sound when it hit a small bump or anything while I was turning slowly. New springs and shocks and it's gone.
I think it has something to do with sagging and the full wheel turn. If you look at the struct bar it looks like it locks into the spindle on a full turn.
Den
Old Feb 13, 2005 | 08:23 PM
mhuppertz's Avatar
My springs are reverse arched. Shocks are new RS 9000 set on full stiff. Where did you get your springs?
Old Feb 13, 2005 | 08:49 PM
Den's Avatar
Den
Ahh. I misread. Mines a 2WD. Sorry about that
Den
Old Feb 13, 2005 | 09:51 PM
rebal's Avatar
have someone turn the wheels left to right and start looking for movement ill bet you will hear and see if you look real close
DodgeMonkey
Jun 26, 2010 09:14 AM
NotMatt
Apr 3, 2007 02:54 AM
Gordonville
Apr 18, 2005 09:45 AM
MonroeDiesel
Mar 5, 2004 02:40 PM
tobyw
Dec 23, 2003 10:39 AM
