crank sensor
Old Apr 25, 2004 | 02:59 PM
adamroofer25's Avatar
crank sensor
Hey guys, my alternator and AC went out at the same time! I finally figured out that it was my crank sensor. Apparently it got sucked into the fan and jerked the wires out flush with the sensor. My question is simple,can I bypass the sensor or will I have to replace it, and if so how much can I expect to spend? Thanks in advance for your time and help.
Old Apr 25, 2004 | 03:12 PM
Monty's Avatar
Yes, you can bypass the crank sensor. In fact, I had to do this for a few days until I could get an external voltage regulator like the earlier first gens ran. I eventually got a new sensor but left the regulator on for an emergency if needed. I think the regulator was about 12 bucks.
I have the directions and pictures that show how to hook up an external regulator at home on my laptop. I will post them for you tonight. Will also put them in the FAQ for future reference.
Old Apr 25, 2004 | 03:19 PM
Thanks Monty, You've been alot of help.
Old Apr 25, 2004 | 10:25 PM
Monty's Avatar
Here is the link to the Tech Facts section that the directions are in. Here are a couple of pictures.
Old Apr 25, 2004 | 10:29 PM
Monty's Avatar
This is where you will need to tie into the alternator. Take the 2 small nuts off that hold the electrical box to the altenator and install your wires form the regulator to the posts. Dont worry, it doesnt matter what wire goes where on the altenator.
92smokin blacky
Feb 28, 2011 02:36 PM
sjester
May 10, 2007 05:03 PM
Gabe32
16
Feb 22, 2007 06:37 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
