Coolant Filter
Old Oct 3, 2005 | 10:41 AM
Tuckerdee's Avatar
Coolant Filter
Just wondering...anybody running a coolant filter? Is it beneficial? Thoughts? Rants? Changed my thermostat over the weekend and just thought it might be cool to have one to keep the crud out of the system better. BTW, I love Cummins! What a sweet design on the housing and o-ring for a fast replacement.
Old Oct 3, 2005 | 02:03 PM
MSM's Avatar
MSM
coolant filters
They really aren't filters per se,the "filter" contains a coolant conditioner that gradually dissolves and is introduced into the coolant. It will tend to keep your cooling system cleaner by reducing rust and scale buildup caused by hard water,corrosives in the coolant,and antifreeze breakdown.The kits aren't that expensive,and will help. They were originally designed for wet sleeve engines as a way to combate cavitation and corrosion pitting of the liners.
Old Oct 3, 2005 | 03:51 PM
csramsey640's Avatar
see above, perfect...If you were running an 8.3l, then yes but more than likely one is already installed. If you do regular coolant changes, you dont need a Coolant Filter Asy.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
Jeremy Cusick
May 13, 2004 07:43 PM
