conversion question
Old Nov 24, 2005 | 11:47 AM
orangefj45's Avatar
conversion question
hey guys, i'm pretty much a newbie to the cumins stuff but i'm willing to listen and learn.
i have an older toyota land cruiser that i'd like to turn into a tow rig for my other cruiser, which is a rock crawler. it's an australian spec vehicle with a stock toyota diesel engine but they really don't put ou a lot of power. the cruiser is a long wheelbase model and weighs enough to be used as a tow rig, so that's not a concern. i know i might as well just buy a dodge truck but i'm addicted to cruisers and wrenching on them so......
here are my concerns:
engine weight: should be able to deal with that with a custom set of leaf springs
transmission and transfer case: i know the stock toyota stuff won't hold up so i'd like to run a NV4500 and a 241HD
axles: the stock stuff won't hold up, that's a fact. so i'm thinking d60 front and d70 rear both slightly narrowed.
cooling: not sure if i'd be able to run an intercooler cause my radiator/grille are not nearly as big as the dodge stuff. and that's really my biggest concern.
i would need this setup to be reliable and not ever to overheat given the limited room i have for the radiator.
so here are my questions: what year engine/donor truck would suit itself for this application?
what are some mild mods i can do to increase the power output without getting too crazy/create cooling problems? i bet nobody has asked this question before, huh?!
i'm thinking about trying to find a wrecked dodge truck that fits the bill and pulling all the components out of it. should be possible. i can handle the conversion work. i have the proper tools, a place to do it and the mechanical aptitude (i hope!!!).
thanks in advance for your input.
georg
Old Nov 24, 2005 | 03:10 PM
frostie's Avatar
this is frustrating. I just met a guy that has a shop. all he does is land cruisers. I cant find his card He and I discussed cummins in a cruiser. he has cruiser pick-ups that were never imported to the US. lots of cool stuff.
I will try and get that info for you.
Old Nov 24, 2005 | 03:54 PM
RBergman's Avatar
someone
on tdr has one w/4bta
http://www.turbodieselregister.com/f...d.php?t=144556
Old Nov 24, 2005 | 07:07 PM
Supernova's Avatar
Try this link, I've been thinking about the same in a pig.
http://www.pirate4x4.com/forum/showt...1&page=1&pp=25
Old Nov 24, 2005 | 08:29 PM
loch's Avatar
Also try www.liquidoffroad.com nice guys.
Old Nov 25, 2005 | 09:29 AM
12valve@heart's Avatar
You might also check at http://www.cummins-conversion.com
There are some individuals there that have done conversions although I don't see any w/ Toyotas but the conversion principles should be basically the same.
Old Nov 25, 2005 | 10:09 AM
mainer's Avatar
Don't do the swap on your LC, The stock diesel crusiers are not easy to find or cheep. Find a gasser and convert that. I got a buddy with a 68 FJ 45 waggon and a 65 40 for sale. The 45 would make a great diesel conversion. It would be a crime to take the diesel out of yours when they are very hard to find in the states.
Cooper
Old Nov 27, 2005 | 11:04 AM
orangefj45's Avatar
thanks for all the replies guys.
the shop in colorado should be proffit's cruisers aka jeremiah. or maybe kurt at cruiseroutfitters.
my diesel is a 1980 which has the early non turbo 6 in it. they have no power at all, especially when you get up in the altitude. i bought this rig for the sole purpose of being my tow vehicle and somewhat of a novelty so i don't mind swapping out the engine. it's not really one of the "desired" diesels in the USA so it won't be a shame to modify it. i own a 63 fj45 wagon as well. won't molest that one as much.......
i've read up some on my buddy andre's site for diesel conversions http://cruisers.shoumatoffmedia.com/ but would like to educate myself as much as possible before diving into this project, which won't even start for at least another 6 months.
one thing i have learned is that i will definetly have to do a suspension lift in order for the engine oil pan to clear the front diff. seems like a minimum of 2" of lift is mandatory. i don;t want to go too tall since this will be a tow rig on narrower axles (5 inches) than a full size truck.
thanks again for the replies, keep em coming. what year engine should i go with and why??????????
GCSS
Mar 27, 2006 09:32 AM
MDMIKE
Nov 24, 2004 06:11 PM
pengyou
Oct 7, 2004 12:10 AM
Superduty12v
13
Sep 11, 2003 07:40 PM
samtheham
Jan 8, 2003 03:02 AM
